Rear springs
Both my rear springs are broken ,2011 f10 with normal and sport suspension abilities. Can the springs be replaced independent of the whole strut? If so what is a good cost effective alternative? Thanks, Jeff
Yes they can and how things are usually done in the automotive mechanics world. If I understood you correctly you'd just need these coil springs which is the OEM part.
| All times are GMT -8. The time now is 10:24 PM. |
