Please help f10 water in rear footwell
Hi and hello.....help my f10 2012 520d has water in my rear right hand footwell can any body with ideas on how to fix the problem please feel free to share...
Are you also experiencing low windshield washer fluid warnings?
open the sunroof and inspect all the drain holes for debris blockage. Go to search on this site and learn about water drains INTO the car by way of drain tubes.
Take all the spare tire equipment out of the trunk well and make sure that there is no water. Also check the trunk side wells for water. Good luck |
did you find the problem?
A known problem on the F10. It's the waterproof membrane inside the rear door which needs replacing. Used to be fixed under warranty.
