The new '12 F10 520i(d) and 528i (525d).
As fitted in the new F10 BMW 520i, the four-cylinder engine develops maximum power of 135 kW/184 hp at 5,000 rpm and peak torque of 270 Newton metres (199 lb-ft), which is available between 1,250 and 4,500 rpm. Instantaneous power response helps the BMW 520i Sedan perform the 0 to 100 km/h (62 mph) sprint in 7.9 seconds (automatic: 8.0 seconds)
In the new BMW 528i, with modified turbocharging and injection technology, the four-cylinder engine develops maximum power of 180 kW/245 hp at 5,000 through 6,500 rpm, and peak torque of 350 Newton metres (258 lb-ft), which is available between 1,250 and 4,800 rpm. 0 to 100 km/h (62 mph) is accomplished in 6.2 seconds for the new BMW 528i Sedan (automatic: 6.3 seconds)
The diesels are even better:
The BMW 525d will get a new four-cylinder diesel engine with BMW TwinPower Turbo technology. This 2.0-litre all-aluminium unit features Variable Twin Turbo two-stage turbocharging and common-rail diesel injection with piezoelectric injectors. The new BMW 525d offers a 10 kW power increase over the previous model, developing 160 kW/218 hp at 4 ,400 rpm. The small turbocharger comes on stream at low engine speeds, while the contribution from the larger turbocharger varies in precise response to throttle requirements. 0-100 km/h (62 mph) acceleration times, which now stand at 7.0 seconds for the Sedan. Average fuel consumption is 5.0 ? 5.3 l/100 km (automatic: 4.8 ? 5.0 litres).
http://www.bmwforum.fi/viewtopic.php...p=18016#p18016
But only with manual transmission.
My Ride: 520d
"From autumn 2011, in parallel with the regular BMW 520d, an ultra-fuel-efficient version of this sedan will be offered: the BMW 520d EfficientDynamics Edition. With unchanged maximum power (135 kW/184 hp) and torque (380 Newton metres / 280 lb-ft), this model records average fuel consumption in the EU test cycle of 4.5 l/100 km (62.8 mpg imp) and CO2 emissions of 119 grams per kilometre."
Tanks !
My Ride: E60
The reason I went ahead and bought my F10 yesterday is because I found out that the newer F10's, starting next month in Taiwan, will be four-cylinder. So I picked up the last SpaceGrey 6-cylinder car they have here in Taiwan..... I still prefer 6 over 4.....
JayArras
05-29-2016 06:35 AM
