F10 Discussion Anything and everything to do with the F10 5 Series. The F10 made it's debut in 2010 as a MY2011.
Heeeeelp :(
Old 03-08-2022, 04:54 PM
Opaniagua's Avatar
My Ride: 2010 bmw 535i xdrive awd
Default Heeeeelp :(
Help!
My coolant pump failed, I replaced it and was making sure all fuses in the glove compartment where good, I took out the abs and dtc fuse on the 25th slot and by mistake placed it in the 24th slot now my brake light abs and awd light won’t go off, also my battery died before I checked the fuses tried the steering sensor reset but light still won’t go away, car drivability has not been affected
Old 03-08-2022, 05:42 PM
donpb's Avatar
My Ride: '06 530i N52
Buy yourself a BMW code reader, because some of those errors need to be reset (meaning they won't reset on their own).
Old 03-08-2022, 06:30 PM
Opaniagua's Avatar
i already tried resetting with the scanner, I’m gonna drive tomorrow to see if the light goes off
the code it gave me was 5D95
Old 03-08-2022, 07:29 PM
donpb's Avatar
So, was there no fuse in slot 24? If you swapped 24 and 25, they're the same value.
Old 03-09-2022, 04:03 AM
Opaniagua's Avatar
no, there was no fuse on slot 24
Old 03-09-2022, 04:16 AM
Opaniagua's Avatar
correction I have no fuse on the 25th slot I put the one I had on 24th slot on the 25th, but that made the anti trap function malfunction, places it back in the 24th slot but what makes no sense to me is that my F1 50 amp is not there and I didn’t take it out and there is nothing on the 25th slot which both fuses are for the abs but it was like that since I bought it and I had no problems.
im trying to find the exact fuse layout for my car but can’t find it all the diagrams I find aren’t for the 2010 bmw 535i xdrive awd
Old 03-09-2022, 06:05 AM
Opaniagua's Avatar
Default Update
All the codes I am getting are dsc related
CF34 message from the dsc, receiver egs, transmitter dsc
instructions check dsc control module
Abs:
5D95 control unit Valve relay (DSC)
6E4F control unit pump activation (Dsc)
5EBA steering angle plausibility (DSC)
cleared all of the except 5D95
Old 03-09-2022, 07:46 AM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
That code is an issue with the pump itself. Are you sure that code wasn't there prior to. If you can't clear it then it needs to be replaced. The relay is internal to the pump.
Old 03-09-2022, 08:19 AM
Opaniagua's Avatar
Default Update
Fixed.
the car was missing 2 fuses
F1 50 amp
F25 30 amp
symptoms with this trifecta lights abs,dsc, and red brake light word along with cruise control not working
Old 03-09-2022, 08:43 AM
Model Year: 05 530i
Engine: 3.0 M54
So the you had the error all along If you had fuses missing. From your initial post that's not what was conveyed.
Quick Reply: Heeeeelp :(
