Full F10 U.S. BROCHURE (electronic version) finally!
U.S. brochure:
http://f10.5post.com/forums/showthread.php?t=405980
Looks like it's the full thing, with all color swatches, options, specs, etc.
Some good reading for the porcelain throne
U.S. brochure:
Model Year: 2010
According to the brochure, this is a standard option across 528i, 535i and 550i:
(1) Vehicle-speed-sensitive variable-assist (Servotronic), variable-ratio power steering
This is an available option on 535i and 550i:
(2) Integral Active Steering with Servotronic power assist (requires Dynamic Handling Package)
I understand (2). I am curious about (1). I was told by a factory rep that all F10 have electro-mechanical Active Steering. Is this true?
I currently have an Active Steering-equipped E60 and would like the same in an F10, without having to opt for the IAS.
My Ride: G30 M550i
Model Year: 2018
I picked up the printed version of this brochure just yesterday...the only difference is that the printed version has an multi-page insert on how the steel "balls" sculpture used in the ads works...
Here's a [clean] .pdf copy you can download directly from this thread:
F10 catalog (US).pdf
I believe they are correct. BMW employes variable ratio steering in all its cars with or without "Active" steering. It simply means they use a rack-and-pinion gearset that has a different tooth pitch (number of teeth per inch) in the center than it has on the outside. This makes the car respond quickly when starting a turn (the rack is near the center), and also reduces effort near the wheel's turning limits.
With active steering they add a planetary gearset approximately in the middle of the shaft that varies the steering wheel lock to lock ratio based on speed. The lower the speed the less turns lock to lock (also a varying ratio but different than the rack and pinion varying ratio).
My Ride: G30 M550i
Model Year: 2018
On the F10, (and unlike the E60), the "Integral Active Steering" includes steerable rear wheels. It may be possible that active steering as we know it on the E60 (front wheel variable ratio only) may be a standard option now and adding AS to a car adds the rear-wheel steering bits...
Model Year: 2010
cobradav's description of variable steering ratio certainly makes sense. I hope Rudy is correct on all F10 having standard Active Steering, with IAS being optional - this is what a BMW factory rep led me to believe.
cobradav's theory may be correct but I'd like to speculate even more...
dead stop. IAS should be like 1.5 turns lock to lock and non IAS 2+ turns.
