F10 Wheel Offsets
My Ride: 2008 535i 6MT
If it is true that the F10 (5) and F07 (GT) share the same offsets:
18" non-stagger ET 30
19" stagger F/R ET 25/39
20" stagger F/R ET 25/41
21" stagger F/R ET 25/41
http://felgenkatalog.auto-treff.com/
Interestingly, from the same site the F01 (7) shares the same offsets with the F07.
not surprised the f01,f07, and f10 all share similar offsets...
thanx for sharing...
![Cool](https://5series.net/forums/images/smilies/cool.gif)
I'm not sure about the 21" wheels but the ET's for OEM F10 wheels both in 19" and 20" are:
F/R ET33/ET44 the wheels being F/R 8,5"/9" and tires F/R 245/275.
Why the rear wheels are only 9" I don't understand.
I know this for sure because I was to order OEM 19" wheels but did then order OEM 20"'s.
See my signature and also this link.
well, the aw f10 that put aftermarket 20's on his f10 and got his wheels to sit flush has offsets of
20X10 offset 35
20x9 offset 32
http://f10.5post.com/forums/showthread.php?t=401721
I asked on page three about his offsets...
20X10 offset 35
20x9 offset 32
20X10 offset 35
20x9 offset 32
20X10 offset 35
20x9 offset 32
but my post was only about the BMW F10 OEM wheels offset's.
The OEM 8,5" front wheel for the 245 tire is OK but the rear's should
be at least 9,5" (now 9"), as it is with the E60 rear rims for 275 tires.
F 9" and R 10" rims will be very nice with somewhat smaller ET's
that the OEM's have for F 245 and R 275-285 tires.
Mine to be 9" rear wheels (OEM Style 312 and ET 44) with 285 tires,
is the widest tire size one should put on a 9" rim.
I'm pretty sure that I have to buy about 5 mm spacers front and even
wider spacers for the rear, but let's see.
ACS wheel offsets for F10
http://www.ac-schnitzer.de/en/bmw-ca...ls-since-2010/
Very similar to posted above:
20X10 offset 35
20x9 offset 32
20X10 offset 35
20x9 offset 32
20X10 offset 35
20x9 offset 32
20X10 offset 35
20x9 offset 32
