F10 Discussion Anything and everything to do with the F10 5 Series. The F10 made it's debut in 2010 as a MY2011.
F10 M550D X-Drive / Transfer Case
Old 04-15-2022, 10:03 AM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Originally Posted by Ristov_
Back left and front left tyre have 1-2mm difference in rolling diameter (circumference)… well within the limits
You should be around a .4% difference with the factory setup which shouldn't be an issue. The one thing that I suspect but no on wants to hear is having a worn front gear. Everything you're describing is pointing to the gear if your tires are indeed good. I guess you would have to ask the previous owner how long was it driven on with different circumstances. Was there a traction that came on during ownership? Other than that I can't think of anything else. Was a transmission relearn performed when you did maintenance on it.
Old 04-15-2022, 10:37 AM
Ristov_'s Avatar
My Ride: F10 M550D xDrive
It was driven for 3 months at least like this…
Transfer Box repair is a must I believe? But why on earth it did not do the pushing thing with the sh*t tyres?
Old 05-24-2022, 01:56 PM
Probation Members
ales croatia f10's Avatar
My Ride: f10!530xd
Hello friend.
I have the same problem as you. I wonder how you solved the problem?
quesofrito
06-01-2020 08:11 PM
andreiATL
10-03-2019 07:42 PM
Kaane
06-02-2019 05:50 PM
erock
03-29-2016 06:12 AM
VarrsToen
06-26-2013 04:51 PM
Quick Reply: F10 M550D X-Drive / Transfer Case
