F10 bit of a porker...
Originally Posted by v_therussian' post='1072638' date='Dec 12 2009, 02:57 PM
Absolutely correct you are
But, for example, let's look at the 535 E60 and 535 F10 - F10 has the N55 single turbo engine (rated at 300hp) against E60's N54 with twin turbos (rated at the same 300hp). Assuming that the weight of the F10 will be somewhere about 300lbs or so (too lazy to do the research ) more than the E60's, you basically don't have to be a rocket scientist to make a conclusion here.
As for the run-flats, aren't the new generation Bridgestone RFTs supposed to be lighter? Not sure what the exact specs are - again, too lazy to do research - but you get the point I'm trying to make... actually, what is the point I was trying to make? LOL I forgot
My Ride: See my signature
Originally Posted by skelevirus' post='1072776' date='Dec 12 2009, 10:05 PM
E60
F10
5GT
5GT meet at the golden corral?
F10
5GT
Originally Posted by sdg1871' post='1072778' date='Dec 12 2009, 07:09 PM
Hmmm. I think I'll take the F10.
Kim Kardash... ummmmm yum yum yum
ill keep dreaming
im not rich enough, good looking enough, or the right color to pull that....
Originally Posted by skelevirus' post='1072779' date='Dec 12 2009, 10:13 PM
+ hell yeah
ill keep dreaming
ill keep dreaming
My Ride: 335i Sedan
ummmhh I think I'll take that steak & cheese orgy!!! lmao I keed, I keed F10 for sure but you definitely used the wrong girl for E60 it should be someone way better than that, no fair
I may be comparing apples/oranges, but the US spec E60 550i (auto trans.) is listed at 3,968 lbs. If the F10 550 is 1830kg, that's 4,026 lbs. - or only a 58 lbs. increase.
Also, BMW's F10 press releases go on and on about all the weight saving features of the F10.
My Ride: 2004 BMW 545i Sport Package, Titanium Gray II Metallic, Wheel Style 124
Originally Posted by skelevirus' post='1072776' date='Dec 12 2009, 07:05 PM
E60
Attachment 95824
F10
Attachment 95825
5GT
Attachment 95826
Attachment 95827
Attachment 95824
F10
Attachment 95825
5GT
Attachment 95826
Attachment 95827
