ERROR! Resetting Permanent SAE Fault Codes [S0751]
My Ride: 2007 BMW 525i
I'm trying to force reset permanent fault codes because I made the mistake of moving to a county with emissions testing. During the healing procedure, however, I'm getting an error any time I try to display the SAE Errors. Most likely because my dumb ass didn't heed the warnings and cleared the fault codes before remedying the problems.
The error reads "IFH-0041: ILLEGAL PARAMETERS" then "Error in testmodule: ABL_DIT_AS1236_SAE_PERM_ANZ". I just reinstalled ISTA+, but it is still giving me the same error. I am now running "Display of permanent fault code cycle status" manually, thinking I need to do this per the alternative healing method, but every time I try the healing it starts lagging like crazy after the first few minutes. Any recommendations? Or, hell, are there any alternative methods to force reset the SAE codes beyond driving for a few hundred miles?
Edit: With how ISTA lags during the test, it's almost like it needs a larger memory allotment. It keeps compounding over time like there's a coding bug.
Edit2: I was finally able to complete the SAE healing test, but still got the same error. Any other ways to clear this sucker?
Alternatively, can someone send me a download link to ISTA+ newer than 4.29.15?
