From DINAN USA Website:
We need to test our turbo software on the following cars and will offer the software download for FREE. We are seeking the following 4 vehicles: ?2010 Z4 sDrive 35i ?X6 xDrive 35i ?X6 xDrive 50i ?535i (6-speed manual only). We need 1 car of a production build prior to 3/08 (MSD 80) and another one after 3/08 (MSD 81) DME. Please call for further details. |
Originally Posted by pennetta
(Post 1113374)
We need to test our turbo software on the following cars and will offer the software download for FREE. We are seeking the following 4 vehicles: ?2010 Z4 sDrive 35i ?X6 xDrive 35i ?X6 xDrive 50i ?535i (6-speed manual only). We need 1 car of a production build prior to 3/08 (MSD 80) and another one after 3/08 (MSD 81) DME. Please call for further details. Do you know what kind of numbers they going to get for tt V8. It can easily be something like 500hp/600lf? Who will need an M5? |
Originally Posted by SergeyM
(Post 1113446)
(Post 1113446)
With the TT V8 the stock numbers are 400 hp and 450 ft lbs, so you should be able to get up to 560 horsepower and 630 ft lbs using the same metrics. The existing M TT V8's have 555 hp and 500 ft lbs stock. |
The Stage I software for the TT V8 looks like it will be +70 hp and +80 ft/lbs to 470hp & 530 ft/lbs.
Stage II will be higher. |
(Post 1123267)
Originally Posted by sdg1871
(Post 1123278)
+70 bhp to a base of 400 sounds on a TT seems like a pretty conservative tune geared more toward durability and reliability than ultimate performance. The torque figure is off the hook and should make for some killer starts. 530 ft/lbs is a tire-melting number.
(Post 1123278)
If Dinan offers a stage II, im sure it will have to have a radiator kit as part of it....time will tell |
M630,
"The Dinan Performance Engine Software safely increases turbo-boost pressure from the stock 8.8 to 13.0 psi, along with properly retuned fuel mixtures, ignition timing and full map rescaling. In fact, over 2000 lines of code have been addressed, producing substantial increases in power output while maintaining the civility and reliability expected of a Dinan performance product. Some examples include: Remapped Water Pump Speeds. In an effort to more effectively control oil and water temperatures, the Dinan software actually increases water pump speeds as boost pressure increases. Boost Pressure Control. Increased boost pressure exceeds the turbochargers? design limitations at higher rpm, potentially shortening their lifespan. Dinan addresses this issue by tapering the boost gradually at higher engine speeds. This approach also addresses the fact that with increased boost at higher rpm the turbocharger temperatures would exceed the intercooler?s ability to cool the intake charge, resulting in a loss of power and compromising the long-term durability of the engine. The tapered boost keeps temperatures within the design limitations so as to optimize output and ensure engine reliability with the added boost pressure." |
