A question for those more audio / technically inclined.
I posted this on the e60 side as well but wanted any/all good input. My problem is specific, but the input Im looking for is broad. Problem: Ive recently done the CIC + Combox upgrade with Bimmerfest. I have full ipod integration with 6NR & FL, and this an important feature for me (more for audio & podcasts, but video as well). BMWs OEM solution is set up so audio coming from this source is an analog signal. This is required to keep the audio & video in sync when playing video off the ipod/phone/touch. Bimmerfest wisely precoded this source to be digital to provide the best fidelity on audio. But the Video is now a second ahead of the audio when playing from my ipod. Bimmerfest has been helpful in letting me choose which solution I want & will change it accordingly. Question: How noticeable to my ear & to my audio system is the analog feed for ipod audio vs. the digital feed? On homestereos I know I need digital to get surround sound & generally highest quality sound. In this case, from what Ive read, it comes down to which DAC (digital to analog converter) I want processing the signal as ultimately it ends up an analog signal. If the port is digital: then the cars DAC does the work If the port is analog: Im relying on the ipod/phone to do the work Presumably the Car does a better job & sounds better? Any / All input is welcome. Correct me if Im wrong above. Key question for me is, can I tell the difference in quality? Ill be doing audio 90% of the time & video 10% of the time, so I don?t want to screw up audio for the sake of video. Is there a way to dry run this so I can compare? |
you are worrying too much about this. in a car environment, you will never tell the difference between digital or analogue.
It doesnt in some way affect the signal processing or the impact of the L7 sound package in a meaningful way?
