2012 F10 535i install M5 Brake Caliper
Hello,
The topic is discussed before. If we want to install M5 6 pot Caliper into non-M F10, we need to use custom bracket into the front axles carrier. I have a idea. If we replace the M5 front axles carrier and hubs, it could install the Caliper without bracket. Using M5 carrier ( part no. 31212284053), related rod and link must be changed to M5 parts together? If it is work, offset of front wheel will push more outside as M5? |
