Are windows factory tinted?
My wife just got pulled over and ticketed for having illegal front tinted window on her E61. I bought the car used and the previous owner tinted the back windows but not the fronts. I have an invoice that confirms that.
As I wanted to make sure that I am in the right before disputing the ticket I checked the front windows with a razor blade and I found a film on the inside. Online the info is allover the place, so my question here is to Canadian E61 owners: Are your front side windows tinted from factory? Is there some official info I can take to court to dispute the ticket? thanks! https://cimg0.ibsrv.net/gimg/5series...d9341b3d4f.jpg A pic or it never happened :) |
Check your VIN with one of those VIN decoders, it should disclose "tinted windows" if it was a factory option.
Originally Posted by pocholin
(Post 1597131)
do your have a film on? |
No factory tint on my Canadian 2010 E61.
I have never seen it an option on the front windows.. any "factory" tint was applied by the dealership independently. Sometimes the glass itself has a higher optical density, usually <2% which is why you get a warning from decent tint installer they will make your tint combined to be legal limit. You might be able to go to court with a document proving you removed anything that was there, but unknowingly thought it was factory. Often a "fix it" ticket will be waived if the problem was fixed. Alberta, where I was born has zero tolerance from when I was growing up. Sure, you can get away with it, but if you're pulled over then you don't have much to fight about it. Once when I was younger the officer gave me the option to peel it off right there and then. I said I had nothing to do it with, he lent me his knife to pick the edge and start peeling :) No ticket was issued. I thought he was a douche, but now that I'm older I think he did me a favor instead of writing up the ticket.
Originally Posted by zenocchio
(Post 1597185)
no mention of tinted windows in the build sheet. Just shadow trimline.
No, your car did not leave BMWs factory looking like that.
thanks guys.
to close the loop on this I went to a tinting shop and they confirmed that my front windows have indeed a film on them. thanks for the help! |
