Will 19 x 9.5 ET33 fit an XiT with a spacer?
Old 05-20-2011 | 06:49 PM
gummysDad's Avatar
My Ride: 08 535xiT - Sapphire Black / Beige
Looking at a set of rims:
Front: 19x 8.5 5x120 ET35
Rear: 19x 9.5 5x120 ET33
I'm sure the fronts will fit, the rears are definitely too deep, but will they work with a spacer, or will I need to roll the fenders?
Old 05-20-2011 | 09:00 PM
colb666's Avatar
My Ride: E91 sport + touring
15mm spacers on all four hubs should see you allright without rolling arches
Old 05-21-2011 | 04:21 AM
gummysDad's Avatar
excellent, thanks
Old 05-22-2011 | 11:07 PM
karman1977's Avatar
My Ride: BMW E61 530d
hello.
i dont wanna make new thread, so can somebody help with spacers.
i have a wheel R19 J9.5 ET25 with tyre 275/30/R19 but inner looks like little catch arcs plastic part.
what wheel spacers do i need?
Thanks
Old 05-23-2011 | 02:41 AM
protams's Avatar
My Ride: 530iA 04
don`t think you`ll need spacers because ET for Xi models is 43, so 33 will stick out for 10 mm.
Old 05-23-2011 | 05:09 AM
gummysDad's Avatar
Wasn't as concerned with the sticking out, but since they are 9.5 in the rear, and the self leveling suspension makes it tighter, was concerned they would rub on the inside
Old 05-23-2011 | 05:29 AM
TLO03's Avatar
My Ride: alpine white 535 E61
Model Year: 08
I did the numbers here. http://www.e90post.com/forums/forumdisplay.php?f=12. The wheel will push out 35 mm on the outside which seems close I THINK not sure you'll have to fender roll and you'll lose 15mm on the strut side. Keep in mind in case of a suspension failure you will want to have clearance or a bad thing can get worst.
Old 05-23-2011 | 07:21 AM
gummysDad's Avatar
Thanks TL. Yeah, don't wanna have to roll fenders or risk rubbing on the inside. Looks like I'll have to pass on these rims.
Old 06-06-2011 | 04:20 AM
karman1977's Avatar
hello.
i have fitted 275/35/R19 at the rear, but i at road where is little pits i have a feel that rear shakes from side to side. i think its not a normal, maybe somebody know why is that?
Old 06-08-2011 | 12:34 PM
ThunderDan's Avatar
Hi GummysDad
Newbie here
Hopefully I'm not asking foolish questions.
Would you care to share more information on the Rims, style, color.
