Where is the rain gutter located in the panorama roof?
Old 10-24-2016, 05:59 AM
  #71
masonmello's Avatar
My Ride: 2006 530xit
First of all I'd like to say this forum is very helpful. I have a 2006 e61 produced 07/05 and am having issues with water in the trunk. It's coming in down the the ketand right rear pillars after a hard rain. I've been researching the drainage and am at a loss. I took the rear passenger wheel off and the drainage plug "+" can't be found. Before i take the bumper off is there a different location? Thank you.
Old 11-24-2020, 06:16 PM
  #72
ripp222's Avatar
My Ride: 07 530xiT
Engine: N52
The manual crank works with less resistance if you unplug the electrical connector from the front sunroof motor.
If you drop the rear portion of your headliner you can approximate where the same manual crank feature exists for the sunshade "floating headliner" motor. Drill a hole in your headliner and operate the manual crank (if you're desperate to get the sunshades open).
I installed 3 of the panoramic kits (front glass, rear glass & floating headliner). It was at least a 12 hour job, partially driven by the hours spent studying the repair instructions and SIB's on the topic. The second time around would probably take half the time. Like other's suggested above, I'd just focus on getting the rear drain tubes cleaned...
tundra
11-10-2016 06:55 AM
umichchris
12-07-2015 03:33 PM
sebash
07-30-2015 12:40 PM
hmilycar
07-07-2015 12:29 PM
kammy6000
07-02-2015 05:05 AM
Quick Reply: Where is the rain gutter located in the panorama roof?
