5Series.net - Forums
-   E61 Touring Discussion (https://5series.net/forums/e61-touring-discussion-4/)
-   -   What is this cable for? (https://5series.net/forums/e61-touring-discussion-4/what-cable-151421/)
Robin Bägeby Jan 14, 2021 12:18 PM
https://cimg9.ibsrv.net/gimg/5series...869ca46dcb.jpg
seanjordan20 Jan 14, 2021 01:14 PM
Your BST. It seems someone just cut the plug off. Do you have an airbag light on. Is there a resistor soldered on the wires.
kd7iwp Jan 14, 2021 01:14 PM
That's in the rear, right? I can't find anything identical on mine. I saw an antenna cable going through there and a wire that connected to the powertrain bus but that was all. I know E46s had a hidden wire on that side in the trunk that they put battery tenders on while they were shipping overseas. What color are the wires inside the black sheath? My PT CAN bus wires are red and blue.
Robin Bägeby Jan 14, 2021 02:00 PM
seanjordan20 I just got it back from the shop they changed the battery and after that the airbag light was on but i cleared the codes and it hasn't come back yet, There is no resistor on the wires.
donpb Jan 14, 2021 02:23 PM
It clearly looks like the BST delete but if so, there should be a 2 ohm resistor in place or else the passenger restraint notification will not clear.
seanjordan20 Jan 14, 2021 02:51 PM
Im clueless to what it is then if you were able to clear the code and there's no resistor on it. Unless there is a simulator under the seat deleting it.
Is there a wire coming out of the positive cable connected to another cable. 2 wire cable
Robin Bägeby Jan 15, 2021 04:10 AM
I checked and there is a little box thats says mat emulator plugged in under the passenger seat, but just incase should i put a resistor on the loose cable?
seanjordan20 Jan 15, 2021 05:29 AM
No, the emulator is bypassing the issue
donpb Jan 15, 2021 11:07 AM
Mystery solved.
