What is this cable for?
Old Jan 14, 2021 | 12:18 PM
Robin Bägeby's Avatar
My Ride: 2005 E61 525i
Default What is this cable for?
Old Jan 14, 2021 | 01:14 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Your BST. It seems someone just cut the plug off. Do you have an airbag light on. Is there a resistor soldered on the wires.
kd7iwp's Avatar
My Ride: 2009 535xi Touring 6MT, 2019 i3s
Engine: N54
That's in the rear, right? I can't find anything identical on mine. I saw an antenna cable going through there and a wire that connected to the powertrain bus but that was all. I know E46s had a hidden wire on that side in the trunk that they put battery tenders on while they were shipping overseas. What color are the wires inside the black sheath? My PT CAN bus wires are red and blue.
Old Jan 14, 2021 | 02:00 PM
seanjordan20 I just got it back from the shop they changed the battery and after that the airbag light was on but i cleared the codes and it hasn't come back yet, There is no resistor on the wires.
Old Jan 14, 2021 | 02:23 PM
donpb's Avatar
My Ride: '06 530i N52
It clearly looks like the BST delete but if so, there should be a 2 ohm resistor in place or else the passenger restraint notification will not clear.
Old Jan 14, 2021 | 02:51 PM
Im clueless to what it is then if you were able to clear the code and there's no resistor on it. Unless there is a simulator under the seat deleting it.
Is there a wire coming out of the positive cable connected to another cable. 2 wire cable
Old Jan 15, 2021 | 04:10 AM
I checked and there is a little box thats says mat emulator plugged in under the passenger seat, but just incase should i put a resistor on the loose cable?
Old Jan 15, 2021 | 05:29 AM
No, the emulator is bypassing the issue
Old Jan 15, 2021 | 11:07 AM
donpb's Avatar
Mystery solved.
Stranger12
Apr 20, 2015 08:03 AM
necompressor
Feb 12, 2015 11:29 AM
BallyM5
Jan 24, 2013 05:32 PM
motorline
Feb 5, 2012 12:32 PM
xxrap985xx
May 20, 2009 01:28 PM
