Weak airflow AC e61
Old 11-17-2022 | 08:21 AM
Jonasand's Avatar
My Ride: Full option 530xd
Default Weak airflow AC e61
So got a bit cold today and for the first time touched the dial to manually crank up fan.
But no matter what i did in i drive, or by knobs it would get a good flow.
Even when setting only dashboard and one went it was just taking it easy.
II could hear the air blower going full steam and air moving inside console.
Battery new and 90% charge
Even took of the inlet filter under hood.
Made no difference.
IIt cant be this weak.. Can it?
Old 11-17-2022 | 02:05 PM
donpb's Avatar
My Ride: '06 530i N52
You might have a faulty vent flap. Did you try both sides? Did you try adjusting your climate settings?
Old 11-17-2022 | 10:17 PM
Jonasand's Avatar
Yeah tried both sides, aswell i could hear the blower amping up after every increase on dial intill it was on max and sounding like a storm, but still low air was coming out.
Where do i check the flaps?
Is there any diy page/video.
I could also hear the air change ways when changing where it should go.
Old 11-17-2022 | 11:45 PM
donpb's Avatar
Actually, your best bet would be to check if it threw any IHKA codes.
Old 11-18-2022 | 02:11 AM
Jonasand's Avatar
Well gonna check with inpa, ista and protool this weekend.
Old 11-18-2022 | 01:00 PM
Jonasand's Avatar
For whoever night have same problem, i found this and changed value.
djbmw
10-21-2021 10:09 AM
Sixracer
06-16-2019 06:59 AM
khooger
Meet & Greet Discussion
42
06-14-2009 06:09 AM
mandisa
E60 M5 Discussion
05-02-2008 01:32 PM
mandisa
05-02-2008 01:19 PM
