Urgent heat needed - rear upper control arm installation
My Ride: 2010 e61 535i xDrive
Hi all,
I’m in a bit of a pickle. I’m installing new rear upper control arms (also called the rear wishbones?) on my e61, and the inward bushing holes won’t line up with the subframe bolt holes. I can’t even get the stock ones back into place. There is zero play in the suspension…I tried jacking up the knuckle towards ride height but it only made the problem worse - it’s like the control arms are now too long by half a centimeter. My intuition says that I should just loosen all trailing arm / integral link connections to see if that does anything, but I don’t have the hardware replacements handy. Any guidance would be appreciated
tenaciousjeebs (01-28-2024)
![](https://cimg4.ibsrv.net/gimg/5series.net-vbulletin/2000x1504/a5cd2272_7757_4b60_bc3c_85e7d66b7407_1af7c7d406a9418fb4a3dfaafe8fdc73204aab6f.jpeg)
This is the stock arm with the outward end installed loosely and unsupported underneath. Jacking it up to ride height only exacerbates the problem
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Is that the only part you took loose? Working on the rear can be hard if the correct parts are not taken out but you should be able to push down on the suspension with a pry bar to line it up. That pic doesn't look like it's too far off. I can't see the rest of the area
That’s the only part I took off so far - the service manual only says to deflate the air suspension, but I didn’t do that because I didn’t think it would have any effect in holding the suspension up. The sway bar link might, and I’ll loosen other items tomorrow morning to see if it does anything.
@seanjordan20 stated "you should be able to push down on the suspension with a pry bar to line it up.".
