Unable to fill my gas tank
My Ride: E61 545i Sport Touring
Mine does this but not at every fuel station. I find pulling nozzle out or turning a bit helps. Sometimes it's nearly all the way out to stop pump tripping.
My Ride: 2006 E61 530xi
Welcome to the forum
I had seen this happen before on other vehicles. It ended up being the ?EVAP Vent Valve?. The valve was stuck closed when it's normally open when the vehicle is not running.
You may need to take the car to a repair facility to determine if that?s the problem.
Good luck!
Good luck!
Vman33
03-14-2022 04:43 AM
