Trying to Find a short
Old 01-24-2021 | 05:44 PM
2006 530xi's Avatar
My Ride: 2006 BMW 530XI
What exactly does this module do? The guy before took all the hatch hydraulics out but this module was all burnt up and I pulled it out just I don't know what it does or other little things. I am sure there is an open fuse somewhere because of this.
Genuine BMW Touring Rear Hatch Control Unit - E61
T#: 144097 | Part#: 61357188110
Part#: 61-35-7-188-110
Part#: 61 35 7 188 110
Old 01-24-2021 | 05:49 PM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
It controls the lift gate. You can't open it electronically without it
Old 01-24-2021 | 06:01 PM
2006 530xi's Avatar
Ok, Thanks. Since I don't have any of the hardware, is it a problem not having this module installed?
Also, another question I have, When I park my car, I notice that back end of my car is sagging after I get of out the Car. Is the Air supposed to stay in the air bags for a while or automatically deflates when I turn CAR off. I wonder if the one of the bags has a hole on in it and the pump is constantly running while I am driving. Check valves bad?
Old 01-24-2021 | 06:56 PM
Model Year: 05 530i
Engine: 3.0 M54
It's just an inconvenience. You car should not be sagging. You may have a leak. You should have an error message.
Old 01-30-2021 | 11:14 AM
2006 530xi's Avatar
So for 2 Weeks, I was able to start the car up every time with not problem. I parked the car up the same way with the rear of the car higher than the front. Opened and closed the Driver side door and the one behind it . Never once opened up the Passenger door or the door behind that one.
Today, I went to add 2 Qt's of Oil and popped the hood up and I had the Driver side door open for a couple of second. Boom, the Short showed up.
Another thing that I have been noticing that when I unlock the Doors ieverytime, My CD Changer goes through its booting sequence. I don't normally use that.
Makes me wonder if the problem in in the Wire harness in the engine compartment going to the DME. In the past, I have had the Hood Closed and short showed up so not sure about that.
This short is elusive as hell.
Old 01-30-2021 | 12:08 PM
donpb's Avatar
My Ride: '06 530i N52
Its probably not what you think it is. I'd keep reading the codes for clues.
Old 01-30-2021 | 01:16 PM
2006 530xi's Avatar
So, one more thing. I charged the battery, it turned ON I was trying to connect inpa and had a laptop issue and gave up. I disconnected everything and was walking away from the car and noticed the Left side Parking light was ON. In the front headlight, the left Angle eyes were ON. I looked inside and Light switch was OFF. I went to start the Car, the short appeared and would not start. Then Angle Eye and parking lights went off. Now I am wondering if the light module is bad. I need a BMW exorcist.
Old 01-30-2021 | 01:34 PM
Model Year: 05 530i
Engine: 3.0 M54
You're going to be wondering for days if you don't read the codes.
Old 01-30-2021 | 03:40 PM
2006 530xi's Avatar
I have a Set of Codes. I will post it Here. I do have the codes from INPA. Just have to figure out how to post it since there are tons of them. I sorted it on Excel and I know what each are just posting here in a organized way. There are too many codes. Even after I cleared it. I have to see if I can convert it to a picture file.
Old 02-06-2021 | 05:57 PM
2006 530xi's Avatar
This constant snow storms are not helping me on isolating this problem. So this is one picture of all the Errors that I can show. The ones with the Alarm, I pulled the fuse since my alarm was going off 2 AM. Alarm is not my main concern. I did pull the Liftgate module out so that is another red one. My Satellite module is also red . The rest of the Yellow ones all seem to have some kind of issue and I assume any one of them could be causing my problem. I am still looking. I will try to load a snap shot of INPA issues later on. There is so much data to look at and I don't know which one is worth chasing and which one isn;t.
Quick Reply: Trying to Find a short
