Transmission issue
Old Jul 6, 2020 | 08:02 PM
2006 530xi's Avatar
My Ride: 2006 BMW 530XI
Default Transmission issue
I am finding more fun issues with the new used bimmer I bought. After I drive the car for good 1/2 hour so, I noticed that if I accelerate too fast, somewhere between Gear 1 and 2 it jerks and I go into limp mode. But If I turn the Car off and let it sit and turn it back on and drive like a normal person, the jerking does not occur. I have access to INPA and general OBDII scanner and on both I get the following code. I did the translating. I am still diagnosing this issue. is there something common with 2006 E61 transmission that will do this. On the high way the car flies, just when I come to a complete stop and accelerate fast, this jerking occurs. Any input on this I would appreciate it.
4F87 Übersetzungsueberwachung Schaltung 1-2: 4F87Gear ratio monitoring circuit 1-2
P17E6 Übersetzungsüberwachung Schaltung 1-2: Gear ratio monitoring circuit 1-2
Umweltsatz Mileage 226584 km Mileage environmental rate
Motoristmoment 224.00 Nm Actual engine torque
Getriebeoeltemperatur 111.00 Grad C Transmission oil temperature
Abbtriebsdrehzahl 800.00 1/min Output speed
Turbinendrehzahl 2784.00 1/min Turbine speed.
Umweltsatz Mileage 226616 km Mileage environmental rate
Motoristmoment 212.00 Nm Actual engine torque
Getriebeoeltemperatur 106.00 Grad C Transmission oil temperature
Abbtriebsdrehzahl 832.00 1/min Output speed
Turbinendrehzahl 2752.00 1/min Turbine speed.
andreiATL
Oct 3, 2019 07:42 PM
BMRMEUP
Feb 23, 2014 12:29 PM
khooger
Meet & Greet Discussion
42
Jun 14, 2009 05:09 AM
mandisa
E60 M5 Discussion
May 2, 2008 12:32 PM
mandisa
May 2, 2008 12:19 PM
