Transmission Fault Code 4f8b
Old Dec 11, 2018 | 07:18 AM
mslc791's Avatar
My Ride: 530xi
Default Transmission Fault Code 4f8b
I am looking for help with my transmission. I have 07 530xi with 6HP19X auto transmission. Last week while upshifting from fifth to sixth gear the car produced the transmission code 4f8b and went into limp mode. I was able to make it back home and reset the adaptation for transmission. All seems to be fine now, it shifts smoother than before (when it jurked before coming to full stop) The car has 87k miles and still has the original “lifetime” transmission fluid. Where should I start or should I let it be and wait for the code to reappear? Any hint is greatly appreciated. Thanks
Old Dec 11, 2018 | 08:32 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
There is an extensive thread covering this issue. Search and you will find it
Old Dec 11, 2018 | 11:09 AM
mslc791's Avatar
My Ride: 530xi
Angry Code 4f8b
Hmmmm, I don’t seem to find anything spelling out the transmission code 4f8b on this blog.
Old Dec 16, 2018 | 03:16 PM
mslc791's Avatar
My Ride: 530xi
Bump. Hard to believe nobody here had seen the 4f8b code?????
Old Dec 20, 2018 | 11:26 AM
Sirius815's Avatar
My Ride: e61 535xi
Do you currently have any hard shifts up or down? Any jerkiness in the transmission? It may be time to do fluid flush and the sleeves/seals above the mechatronics.
Old Dec 24, 2018 | 03:36 AM
gman6262's Avatar
My Ride: 2010 535xiT Touring, N54, Individual Audio
Model Year: 2010
Engine: N54 3.0L Twin Turbo
I would second the fluid flush. The lifetime fluids aren’t really lifetime. If you drop the pan you can check the magnets for metal, and while you’re there, put in a new pan/filter. Your code is mentioned in this thread: https://5series.net/forums/diy-do-yo...137584/page17/ next step would be solenoids and seals. Good luck, let us know what you decide to do.
colincoon
Mar 15, 2016 07:39 PM
knklhead
Jan 8, 2015 03:20 PM
ROMAL
Dec 7, 2011 11:25 AM
edin535d
Oct 2, 2009 01:04 AM
Blanco545i
Sep 19, 2007 05:11 AM
