TPMS warning light persists even after RDC module was replaced
![Angry](https://5series.net/forums/images/icons/icon8.gif)
I did some research and determined the RDC module with part number 6 782 800-01 was the culprit so I purchased another one from ebay with the same part number but I still get the same error message about the TPMS not working. Even unplugging the RDC module completely does not change the error message state at all.
Is there some codes that will help me find out what is going on at a deeper level? I don't want to keep buying parts. I double checked the tire pressure and none of the tires are out of spec from the last time I set the system.
Is there a reset procedure perhaps?
PelicanParts.com
08-13-2015 01:45 PM
