Tailgate wiring harness replacement??
Old 03-28-2015, 06:11 PM
  #321
remyek's Avatar
My Ride: 535D 2008
Old 03-29-2015, 10:58 AM
  #322
InsipidMonkey's Avatar
Have you checked your fuses?
https://5series.net/forums/e61-touri...4/#post1532023
Old 03-29-2015, 03:56 PM
  #323
remyek's Avatar
My Ride: 535D 2008
Yea all of the ones for it :/
Old 03-29-2015, 04:01 PM
  #324
remyek's Avatar
My Ride: 535D 2008
Any suggestions ?
Old 04-12-2015, 11:33 AM
  #325
paul0000's Avatar
My Ride: 530d
Hi everyone,
I wanted to say thanks for the knowledge and info sharing on this thread!
My 2007 E61 had a left hand number plate bulb warning recently and I changed the bulb with no luck. Googling got me here.
After looking at the wires and putting things back together I had both number plate bulbs and a rear fog light erroring.
I took the plunge and pulled the right drivers side loom through the speaker and found 3 totally broken wires and most of the others frayed. Temporary repair in place whilst I wait for some solder to arrive.
Would welcome some advice on what tape / cover to out over the solder connections?
Thanks!
Old 04-13-2015, 03:29 AM
  #326
J_K
J_K's Avatar
My Ride: 530D Touring
I used these. http://www.ebay.co.uk/itm/Solder-Hea...item4acc80f126
Guaranteed connection and insulation.
Not cheap but I'm impressed by these things everytime I use them.
You'll probably reds and blues.
Old 04-13-2015, 08:46 AM
  #327
Lotus99's Avatar
Cool. Hadn't heard of "Solder Heatshrink Butt Splice Terminal Connectors" before. Would a hair dryer be hot enough to melt the solder? Or must be a heat gun?
Old 04-13-2015, 11:29 AM
  #328
J_K
J_K's Avatar
I use a small gas soldering iron with a flame showing.
Not sure about hair dryer.. Heat gun does work though for sure.
Old 04-19-2015, 02:22 PM
  #329
NOCOBMW's Avatar
My Ride: E61
Hello.
I recently repaired all 4 wires in the looms on my 2006 E61 wagon which fixed many of the related problems. However, the rear glass window still would not open. This also led to my interior lights not turning off unless I manually did from the inside (button on sealing) and the rear wiper from working, although ever so often it will move a few inches.
The great information from this thread led me to the microswitch replacement, which I purchased from a BMW dealer out of Atlanta and replaced.
Unfortunately, the problem still persists with the window, wiper, and interior lights, which led me to this posting.
During my wire repair, I only had two sized wire gauges which either matched the current wire size or was a larger gauge. Would this create any problems with conductivity?
Also, does anyone have suggestions or thoughts on fixing this.
Thank you.
Old 04-19-2015, 11:46 PM
  #330
J_K
J_K's Avatar
Bigger is ok. Smaller isn't.
A smaller wire would restrict current flow and overheat whereas a larger wire won't.
Do you need to add wire?
Mine was a simple join the ends back together job...
Quick Reply: Tailgate wiring harness replacement??
