5Series.net - Forums
-   E61 Touring Discussion (https://5series.net/forums/e61-touring-discussion-4/)
-   -   Tailgate wiring (https://5series.net/forums/e61-touring-discussion-4/tailgate-wiring-147999/)
Marton__ Dec 24, 2017 02:28 AM
Tailgate wiring
Hi.
i just changed the wiring harness in the boot of my e61. When i finished and went for a drive, the open boot alarm came in the idrive and the rear wiper doesn't work.
This was not the case before i changed thr wires.
i have checked the wiring two times, all wires are where they should. Really frustrating.
anyone have a clue what this might be?
Daniel
julienjj Dec 24, 2017 04:26 AM
The wiper will not work unless the booth is closed. If you have some diagnosis equipement (inpa or a high end scanner)you can read the status of the door latches while you play with it
Marton__ Dec 24, 2017 05:02 AM
Okay. I thaught maybe the micro switch could be the problem. I have carly obd. Will check it out later tl day.
