E61 Lowering/Firming Up with self -levelling.
Old 03-29-2010, 02:56 AM
Persuader's Avatar
Hi. I want to lower/firm up my non-m-sport E61(self levelling) and am a little confused.
Do I just get front springs and have the rear re-programmed but if so does this not make front firmer ride but rear still soft or are you meant to get front & back springs as well as getting rear reprogrammed. It just seems to be that most spring kits for the E61 are only for the front because of the self-levelling suspension.
Cheers
Old 03-29-2010, 03:53 AM
Persuader's Avatar
Further to above post I have now had some e-mails back from suppliers stating that only the front springs are supplied for the E61 with Self-Levelling. However does this mean car is firmer on front than back???
Old 03-29-2010, 05:44 AM
Patrick E61's Avatar
My Ride: 2005 BMW 530d M-Sport TouringExterior: Titansilber Metallic, M5 mirrors, ACS rear roof spoiler, BMW Carbon Fiber rear diffuser, Adaptive Xenon headlights, AngeliBright v.3 Angel Eyes, F1 Autohaus Euphoria 6000K LED license plate lightsInterior: Black
You could always add a E60 M5 rear anti-sway bar. I did, but no clue if it is any better.
I suppose that with the rear lowered, it will be somewhat "firmer" just because there is less travel in the suspension.
Old 03-29-2010, 05:51 AM
karman1977's Avatar
My Ride: BMW E61 530d
Cheers
as i understand that front lowering is performed by springs, rear only by programming leveling system.
if You want firmer ride then U can change to Sport schock absorbers
hope it helps, if somewhere iam wrong then clever Guys can correct me
Old 03-30-2010, 10:38 PM
StreetPro's Avatar
My Ride: 525DTM
imo the rear should be softer because of lesser pressure in bags (to rise the car higher, you have to rise the pressure as well)... I dont know if it is any significant change, I plan doing this in a month or so (I have Eibach front springs on the shelf, rear will be dropped via rotating the position-sensing arm on suspention)
Old 04-06-2010, 03:43 PM
Nels996's Avatar
My Ride: 2006 E61 530xi
Maybe I can share my experience with lowering my E61. I used a set of H&R front springs
-35mm. I reprogrammed the rear suspension to match the ride height in the front. The first thing I noticed is the rear is slightly stiffer, and the compression rate was reduced.
Hope I helped.
Old 04-06-2010, 11:35 PM
mvd
mvd's Avatar
My Ride: E63 650i
Just buy these
Hartge, comes with new pair of rear leveling joints.
Old 04-09-2010, 04:41 AM
tac76's Avatar
Originally Posted by mvd
Just buy these
Is the leveling joints longer or shorter than OEM??
Old 04-09-2010, 07:54 AM
mvd
mvd's Avatar
My Ride: E63 650i
Shorter...drops about -30mm
< - like that
Old 04-09-2010, 09:02 AM
Spartan335i's Avatar
My Ride: 06' 530xi E61 Saphire Black / Dakota Black - aluminum 11' A4 Avant 2.0T Brilliant Black / Black - aluminum
Just buy these
This is what some were talking about!!!
I asked Nels996 if the H&R cames with the rear brackets and do not!
Interesting!
Quick Reply: E61 Lowering/Firming Up with self -levelling.
