Sunroof tilt mode pops open and pops closed
My Ride: 2006 530xi wagon
So my wagons sunroof has started to catch on something when going into vent position and sometimes when closing the vent setting. Seems like it kinda pops open and pops closed. Almost looks like the glass panels are catching on each other. Any ideas on a fix?
My Ride: E61
I'd have listed them in a different order, but that's probably a more responsible orientation. The recalibration takes zero tools, almost as much time, and will likely cure what ails you. You just press the button in one direction (slide open, if memory serves) until it finishes doing its thing, IIRC.
Recalibrate usually fixes it as I had a similar issue. Have you tried to help it along by hand? Is the shade panel pulled back to see if the wind screen is causing interference?
yeah I’ve tried with shade forward and backward, seems to do it either way. Looks like the 2 glass panels are sticking to each other where they meet.
Lotus99
08-04-2011 10:22 AM
