strange electrics
My Ride: 2007 E61 M5, 1989 Z1
Yesterday around midday comfort access didn't work so I had to use the remote to unlock the car and open the tailgate. Closed the car up, locked it and walked away - when I walked by 30 minutes later the tailgate glass was open.
Got in the car in the evening and get two error message : high rate of battery discharge and that the date and time needs setting. Can't remember if I used comfort access or not. Started the car and the tailgate glass popped open. Set the clock (date was fine). Stopped for fuel and when I started the car the glass popped open again.
This morning comfort access didn't work again. Unlocked the car and the glass popped open. And the clock needed setting. And then I couldn't open the tailgate glass with the push button under the handle.
No rain to speak of in the last 10 days or so. Any ideas where to start looking? The car is under warranty but if I can throw £50 of parts at the car that are a a straight-forward DIY I would rather do that than have the hassle of dropping it off and having them keep the car for a couple of days.
Sounds like a normal problem with the E61
The wirering for the tail gate, is broken. That would be what I would look into.
Example from here in Denmark : http://mobilteknik.dk/forum/24-monte...agklap-skiftet
Hope you solve it
Hope you solve it
My Ride: 2004 E61 530D - Dynamic Drive - Active Front Steering Sport Seats - Voice Control - Head Up Display - Nav Pro - Bluetooth - Panoramic roof - Front/rear heated seats
What Holtz said:
Combination of rear window (switch), reception and resets points straight at the tailgate wiring looms.
It is DIY-able, however within warranty:
take it to the dealer, if they screw up it you can confront them later on etc..
Besides they'll have addressed the looms in many, many E61's before so chances are they'll fix it quick and competently.
Good luck!
Good luck!
If CA isn't working, it could be the diversity module's crapped out under the rear spoiler, I thought? That's what my issue was.
Of course these all could be unrelated problems, the infamous switch for the tailgate glass, diversity module for comfort access and something like a bad IBS for the battery but if one single common issue very well could cause all these symptoms that might be the first thing to look at in this case.
Good luck!
Well, the car's booked in for 2 days on the 30th - fingers crossed it gets sorted and doesn't leave me in the lurch in the mean time...
Car still at the dealer (2 day stay as planned) and they're saying it was only the switch for the glass portion of the tailgate that is the root cause. Battery charge overnight and testing tomorrow. I remain a polite sceptic that the switch alone could cause all those issues.
