Sound system upgrade revisited
#22
My Ride: M3
Model Year: 2017
I will, and guess that means running 2 sets of wires between amp and each sub - but that shouldnt be twice the work.
discussing sws-8 on a seperate thread where one member added a 4mm spacer when he installed them. any idea whether that is required or just cream on top?
#23
In the E60 the spaces are not needed. The earthquakes seems to fit in well.
#24
My Ride: 535XIT Space Gray, Cream Beige LeatherCold Weather, Premium, Auto, Rear Side Window Shapes, Heated Rear Seats, Park Distance, Navigation, Satellite Radio
Model Year: 08
I am interested in upgrading my base system, is front speakers the biggest bang for the buck?
What brand should I use?
What about under seat subs?
#25
I have upgraded my under-floor speakers to SWS8's and fitted Logic 7 mids and tweeters in the front doors. I am driving the subs and new door speakers with a pair of extra amps mounted under the front seats. All looks standard and the sound is massively improved. I have left the rear speakers standard, but fitted tweeters, which like the fronts are plug and play.
On my LCI car the Sub enclosures had ribs in the bottom that I had to dremel out to get the SWS8's to fit. Much neater than a spacer that raises up the speaker risks that the speaker cone would foul the seat runner or carpet.
#26
Model Year: 08
With regard to the under seat subs are the wires in place or did you have run new ones?
Did you need to change the I Drive setting?
#27
hm, that came 1 day too late I'm afraid. I've ordered the Logic7 tweeter and mid-range for the door. Meantime I've ordered a set of Earthquake SWS-8 subwoofers, pared to an Earthquake TNT T1000W2 amp. I plan to plug the amp into one of the rear roof mounted speakers, with a remote on-off wire coupled to the cigarette lighter outlet in the boot area.
In case anyone know of a pictorial dealing with a similar install, please let me know.
Sooooo - what's the latest?
incoherent
04-15-2015 04:48 PM
