5Series.net - Forums
-   E61 Touring Discussion (https://5series.net/forums/e61-touring-discussion-4/)
-   -   Software up grade (https://5series.net/forums/e61-touring-discussion-4/software-up-grade-145647/)
Allan Clark Sep 13, 2016 11:09 AM
Software up grade
Can anyone tell me how I can upgrade my on board computer so that I can get sat nav and Bluetooth? I only have basic model 5 series 525d se tourer on a 56 plate ?? Or do I have to upgrade the whole computer ???
KyleB Sep 14, 2016 02:23 AM
you can either:
A. retrofit CCC, CIC, or NBT ('upgrade the whole computer')
B. install an interface that allows you to run navigation and bluetooth through your existing system
neither one is cheap per-say, and both require varying levels of disassembly. there is plenty of information available on the internets to help you decide.
good luck.
Allan Clark Sep 14, 2016 02:28 AM
Is this software or hard ware ???
Originally Posted by KyleB (Post 1582117)
you can either:
good luck.
Sorry m8 and thank you for all your help !but is this 'ccc' hard ware or software ? Sorry I'm I bit thick when it comes to this sort of thing and what does 'ccc' ,'cic','nbt' mean ??
BostonJon Sep 14, 2016 11:49 AM
you have the non-nav i-drive business "M-ASK" system with the smaller screen
"CCC" is the DVD-based nav system that was used until about 2007 and has the larger/wider screen.
"CIC" is a hard-drive based nav system that started in 2008 and has a quicker interface.
"NBT" or "CIC-HIGH" was introduced in late 2012.
https://en.wikipedia.org/wiki/IDrive
Allan Clark Sep 14, 2016 03:42 PM
Mine is a 2006 mobile? Can I fit a ccc to mine ?
BostonJon Sep 15, 2016 04:35 AM
Yes- but if you're going to go through the trouble of a retrofit, why not get the newer CIC system?
Allan Clark Sep 15, 2016 06:42 AM
To be honest I'm not sure what is fitted to my car ? I have a screen that does communications, entertainment..... does this help ??
KyleB Sep 15, 2016 12:17 PM
google is your friend.
BostonJon Sep 15, 2016 03:02 PM
yah, not to be rude, but if you've gotten far enough as registering on this forum and posting in the appropriate section, you should be capable of googling all this information.
Allan Clark Sep 15, 2016 05:29 PM
Very true but I just wanted to find a Base to start my research from :) thank you all for your help
