RLS sensor initialization
Old Aug 5, 2023 | 01:32 PM
pavjayt's Avatar
My Ride: E61
Model Year: 2009
Engine: N54
Default RLS sensor initialization (RESOLVED)
Hi all,
How can one do RLS initialization? I am having this error in both my RLS module and DSC module, initialization error. I didn't come across a proper procedure of doing this initialization. INPA have activate option, but it doesn't guide you or tell you what or when it is happening or happened.
I see BMW used various of these sensors depending on what options the car came with. Mine has HUD, LDW and auto wipers and headlights with auto leveling.
RLS error - A129
DSC error - 5ED2
thanks for any suggestions
Old Aug 5, 2023 | 02:23 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
It should be a simple replacement and reset. The reset is instant so there's no other notifications that come up. Once it's reset you clear code.
Old Aug 5, 2023 | 05:47 PM
spectre6000's Avatar
My Ride: E61
Does this mean you replace the sensor(, clear the code), and it's just happy again?
Old Aug 5, 2023 | 05:54 PM
pavjayt's Avatar
My Ride: E61
Model Year: 2009
Engine: N54
I never replaced the sensor or windshield, it showed up when I did software update via NCSExpert (while I am getting familiar with it and practice on small modules) and since then it is lingering around in the codes and just reappears even when I clear it and do Activate->Initialize, no matter how many times I do.
Old Aug 5, 2023 | 07:30 PM
No a reset needs to be done like stated then clear code
Old Aug 6, 2023 | 07:36 AM
My Ride: E61
"Reset" doesn't mean much to me in this context (yet), unfortunately. Can you elaborate/be more specific? I'm about to have to do this with a new windshield in a week or so with the replacement sensor currently in the mail.
Old Aug 6, 2023 | 07:46 AM
You perform a reset in INPA or ISTA. Whichever program you have. I don't know any other way to elaborate a reset needs to be done. Probably best for you to let the company whose changing the windshield handle it.
Old Aug 6, 2023 | 07:48 AM
My Ride: E61
INPA/INSTA process. Got it. My glass guy doesn't do that stuff. Just installs. Old school. I have a shop grade scanner that might have the option. Otherwise, I'll have to tap a friend down in town that I know has a laptop set up with one/both of those.
Old Aug 6, 2023 | 05:44 PM
pavjayt's Avatar
My Ride: E61
Model Year: 2009
Engine: N54
I just tried it again by doing Init in INPA and then erasing the code. It came back almost immediately. Looks like I have to use ISTA service function to see if that makes any difference. Any more thoughts???
At least the light sensor is working since I can see the light values change in INPA analog values section when I shine light over it.
Old Aug 7, 2023 | 06:05 AM
kd7iwp's Avatar
My Ride: 2009 535xi Touring 6MT, 2019 i3s
Engine: N54
On my E46 when I retrofitted RLS (I installed my own prism on the glass since i hadn’t changed the windshield) I kept telling it to initialize and the error wouldn’t go away. Turned out I had a bad sensor. Borrowed the sensor from a friend’s car and it instantly initialized. Then later got a crack in my windshield and got a new one with prism and it worked much better. I recognize this is a different platform than the E60 but it is possible your sensor is bad? On the E46 you tell it to initialize, then turn the key off and back on and that’s when it either initializes or sets a code.
