Rim Information!
Old 02-07-2010, 08:07 AM
ExCon's Avatar
My Ride: BMW M5 E60 2006
Hi,
I would like to Buy New rims an tyeres.
Found the rims I would like to have but only in 22x10... (22x9 would be perfekt)
and now i wounder if they fitt and in that case whit which offset?? (I can order any offset i Would like from 0 - +45)
tyres are 235/30 r22 toyo proxes
Old 02-07-2010, 11:54 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
You are lost man!
22" is way too big size for the E60. Are you serious?
And with that tire size you will never get them fit:
235/30 R22 --> overall diameter is 699.77 mm
And the right size with a 19" wheel would be:
245/35 R19 --> overall diameter is 654.05 mm
I think it would be very difficult to find the right tyre for the 22" rim to fit E60.
Or are you doing some serious body modding?
You really should do some research about the issue.
- Antti -
edit: Take a look at
. They have managed to get 245/30 R22 tyres to fit, but it has required widening the wheel arch.
Old 02-07-2010, 12:03 PM
ExCon's Avatar
NO i´m not LOST!
I have seen a lot of e60 / e61 whit 22"
And the link that you send is a lowered e60 whit m-tech chassie.
I have a stock E61 no lowering or so.
And I will get some other offset so the rims dosen´t have to come out near the arch.
about the research, i have searched for a very long time and bought a set of 20x10 and 20x8,5 but i want bigger NOW!!! =)
Old 02-07-2010, 12:10 PM
Anzafin's Avatar
Originally Posted by ExCon
NO i´m not LOST!
Ok.
I think 10" wheel is too wide in front with any offset, but I'm not sure. With M5 front fenders they would fit with the right offset though...
Old 02-07-2010, 11:53 PM
juliann's Avatar
My Ride: 535d Sport Tourer - E34 M5 Race Car
Measure what inner clearance you currently have from the rim / tyre (tire) to the strut.
Then use this tool to compare current clearance vs proposed. : http://www.morfed.net/wheel-offset-calculator/
The 19" E61 BMW wheels are 8.5J ET18, with 245/35's. With the 22's, and the 235/30's, you are increasing the diameter by 5cm approx.
You then need to consider inner clearance, wheel arch diameter (and effect on full lock), wheel extension beyond arch - let alone availability of tyres and ride comfort.
Old 02-23-2010, 02:36 AM
ExCon's Avatar
Thanks for all the info but now ihave changed my plan´s for the car again.. I have bought 18x9,5 offset 20 and gonna go whit 215/35-18 =)an lower the car whit coilovers. the rims ar Breyton Vision.
Old 02-23-2010, 03:12 AM
xBMWx's Avatar
Those pretty thin tires for an 18" E60 wheel -- you get 245s on the M135 M-Sport factory supplied rims. Why go for such thin tyres??
Old 02-23-2010, 04:24 AM
ExCon's Avatar
i´m gona o for a Germanylook styling (you know like bmw e30 whit borbet 16x9" rims whit 205/40-16)
My e61 will get coilovers, yellow tinted headlights and fog lights, using sandpapper to remove the paint on the hood and then let it rust! =)
Old 02-23-2010, 09:11 AM
juliann's Avatar
If the 'hood' were steel, it could well rust
Old 02-23-2010, 10:18 AM
Kuul4's Avatar
My Ride: E61 535d
I'm really looking forward in seeing this project to proceed.. Pics pics pics! Especially from the sanding project..
Quick Reply: Rim Information!
