Resetting service indicator
Old 12-01-2010, 11:59 PM
Kell's Avatar
My Ride: 2005 530d M Sport Touring : Carbon Black : Half Leather : Pro DVD Sav Nav : TV : Active Cruise : Front/Rear Parking : Bluetooth Phone : 6 CD : Dark Poplar Wood : Folding Mirrors : 5 year Servicing Pack
Hi all. Recently had our brake fluid, pads and discs changed after the service indicator flashed up. Had the front discs changed at the same time. This was done at Kwik Fit rather than BMW as it was about half the price.
Anyway. While they reset the indicator for the pads, the car's still saying the brake fluid needs doing.
Normally, you can just go into the service menu and reset, but I don't seem able to this time. Is it possible to reset this yourself, or does the dealer need to do it?
Old 12-02-2010, 10:12 AM
Trinity Autosport's Avatar
My Ride: F10 M5
Model Year: 2013
You can reset it yourself.
- Turn key to on position
- press and hold reset on gauge cluster
- when you see the brake fluid logo press and hold the reset button
- it'll say rest? let go of the button and press and hold the reset button again
- it should reset
Old 12-06-2010, 03:32 AM
Kell's Avatar
THanks for that.
I'll give it a go later on. If I remember.
Old 12-12-2010, 06:48 AM
Kell's Avatar
Nice one. Took a couple of attempts as I went into some weird and wonderful text. But got there in the end.
Old 12-13-2010, 05:15 AM
pmgoliv's Avatar
That must be the hidden menus of the OBC.
Gives important info about several things, like coolant temperature (as no temperature gauge is available on E60/E61).
Old 12-13-2010, 10:15 AM
Rasmus's Avatar
Guess you mean "no precise" temperatur gauge"?
The gauge at the RPM meter is sufficient to me as it give an OK indication of the engine temperatur with repect to normal working temeprature which is 8 lines left on my 530D.
Old 12-13-2010, 10:19 PM
puerco's Avatar
My Ride: E61 530D Msport 260@600
Before you get service menu in screen you have to reset your tripmeter. 00000.
-Then you press about 5sek trip and got triangle symbol in screen.
-Then click trip so many times, you see Brakefluid symbol.
-Hold down trip some times trip and yuo get message "RESET"
-Hold trip down and you see KM got 00000
Secret "hidden" OBC here
http://www.scoopz.com/m5board/E60_Hi...structions.pdf
(sorry my english)
Old 12-14-2010, 02:09 AM
jay77's Avatar
http://www.scoopz.co...nstructions.pdf
(sorry my english)
Make sure you do this with the drivers door closed A friend called me and I went through it with him at least 10 times and then I made him get out of the car, and lock the car wait 20 mins and start again..its only when I said get in the car, and now close the door..and I heard "ah i didnt do that before"
Old 12-16-2010, 04:44 AM
pmgoliv's Avatar
Not in the LCI models. Mine is a 530d LCI Touring and there is no indication for temperature in the RPM meter.
I use the hidden menus in the OBC.
Old 12-17-2010, 01:05 AM
Kell's Avatar
I genuinely can't remember if I had the door shut or not, but I'd have said not as my daughter was in the house alone and I didn't want her to panic and wonder where I was.
Quick Reply: Resetting service indicator
