Rear Wiper Blade
My Ride: '02 K1200RS
'03 R1200CLC
'06 530xi Speedwagon
How do you change the rear wiper blade? The owners manual is useless when it comes to basic maintenance and I don't have a repair manual yet. Any help would be appreciated.
Thanks,
Steve
Thanks,
Steve
Just pull the inner arm out. I tend to lever it, using the arm itself from one end. The normal looking inner just clips in.
It can be a bit stiff. I say normal looking because I've yet to find a normal arm that fits the spindle and is narrow enough to fit properly. Even though the original arm is Bosch a normal Bosch 15" (or whatever it is) doesn't fit properly.
My Ride: E61 535d carbon black m-kit panoramaroof with beige nasca interior and wood trim. 172m rims. DimSport Race, SB, SAT
Hm, how many "arms" are there? I count one! Or are you referring to the rubber blade itself? I.e. leaving the arm put, sliding the rubber blade off and sliding a new one on the existing arm? I haven't done this myself and am curious to learn, but I don't quite get your description, I'm afraid.
Allright, I guess you are referring to item 1. http://www.realoem.com/bmw/showparts...21&hg=61&fg=45
'03 R1200CLC
I just want to replace the wiper blade itself. I was having trouble getting a good look under the blade cover because of snow and ice so I was hoping for some experienced input.
Steve
Steve
'03 R1200CLC
Thanks for the help. Also found answers in the section of the manual about replacing components. Didn't realize there was such a section.
Steve
![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
Steve
TexaZ3
05-06-2015 09:54 AM
