Power tailgate hydraulic cylinder dismounted
#31
My Ride: 2005 BMW 535d Individual
Model Year: 2005 BMW 535d Individual
Engine: 535d
With the new ball joint mine is staying in a lot better. It definitely made a nice snap and took some effort to the hydraulic arm onto the ball.
Unfortunately it still falls off, just a lot less often. I guess i need to find that snap ring? Thanks for those pictures - anyone have an idea where to get something for this?
McMaster has these https://www.mcmaster.com/#retaining-rings/=16xq0sy
Not sure if this would work or not?
Or maybe this is better - https://www.springmasters.com/sp/int...nap-rings.html
Would you say given the one you found - would one be better with a clip a little bigger or a little smaller, as I can't seem to find one that matches the dimensions of what you found and used.
As you can see, the one I found and am using has an inside diameter of 9,80mm and an outside diameter of 12,30mm the thickness of the wire/ring is 1,26mm.
Round Wire Snap Rings: Carbon Spring Steel Retaining Ring & C-Clips SimplyBearings has wire snap rings and I would send them an e-mail asking if they could help me find the correct size or do some extensive searching on the interwebs.
#32
My Ride: 2008 535xi Wagon
Thanks. Now I know the name of what I'm supposed to be looking for. That shop yo linked to is a bearings shop, but located outside the US.
I think there is a bearing shop located near me here in Boston, so I'll try to talk to them.
Thanks again!
Thanks again!
#34
Just talked to an online retailer - and found this https://www.huyett.com/Products/Fast...chText=drb-010
may be the closest, but seems to not match your specs?
I believe the ball is sized 10mm (at least that is what it is called out as). I assume that is the ball size, and not the thread size?
#35
Engine: 535d
The thickness of the original ring (1,4 mm) is almost double the size as the one on that page (0,8 mm).
I measured the diameter of the ball (BMW part# 41627148797) and it is 10 mm.
#36
My Ride: 535xi wagon
Engine: N54
This was already done on the touring I bought and I don't miss the power functionality at all.
My wife's MDX has the power liftgate and truthfully, we only used it a handful of times throughout our ownership thus far. Otherwise we normally shut it manually most of the time.
thanks
#37
My Ride: 535xiT
Others have mentioned this, but I'll throw in my advice as well- I drilled a small hole in the lift arm "socket" as tight as I could to the "shoulder" of the ball, and stuck a cotter pin of sorts through there. The arm never pops off the ball now, and I didn't have to order any special parts.
#40
Engine: 535d
A rubber mallet or a hammer and a piece of wood would work. I used a hammer and a piece of plastic to pop mine in place on the ball bolt. It has as been working like a charm ever since.
