Power tailgate hydraulic cylinder dismounted
Old 04-13-2017, 03:10 AM
  #31
BMW E61 535d's Avatar
My Ride: 2005 BMW 535d Individual
Model Year: 2005 BMW 535d Individual
Engine: 535d
Originally Posted by kguarnotta
With the new ball joint mine is staying in a lot better. It definitely made a nice snap and took some effort to the hydraulic arm onto the ball.
Unfortunately it still falls off, just a lot less often. I guess i need to find that snap ring? Thanks for those pictures - anyone have an idea where to get something for this?
McMaster has these https://www.mcmaster.com/#retaining-rings/=16xq0sy
Not sure if this would work or not?
Or maybe this is better - https://www.springmasters.com/sp/int...nap-rings.html
Would you say given the one you found - would one be better with a clip a little bigger or a little smaller, as I can't seem to find one that matches the dimensions of what you found and used.
Hi, I don't think any of the snap rings you linked to will work. What you need is a "Round Wire Snap Ring" with an inside diameter just a little bit smaller than 10mm.
As you can see, the one I found and am using has an inside diameter of 9,80mm and an outside diameter of 12,30mm the thickness of the wire/ring is 1,26mm.
Round Wire Snap Rings: Carbon Spring Steel Retaining Ring & C-Clips SimplyBearings has wire snap rings and I would send them an e-mail asking if they could help me find the correct size or do some extensive searching on the interwebs.
Old 04-18-2017, 04:06 AM
  #32
kguarnotta's Avatar
My Ride: 2008 535xi Wagon
Thanks. Now I know the name of what I'm supposed to be looking for. That shop yo linked to is a bearings shop, but located outside the US.
I think there is a bearing shop located near me here in Boston, so I'll try to talk to them.
Thanks again!
Old 04-18-2017, 04:16 AM
  #33
Engine: 535d
Good luck! Keep us updated!
Old 04-18-2017, 08:20 AM
  #34
kguarnotta's Avatar
Just talked to an online retailer - and found this https://www.huyett.com/Products/Fast...chText=drb-010
may be the closest, but seems to not match your specs?
I believe the ball is sized 10mm (at least that is what it is called out as). I assume that is the ball size, and not the thread size?
Old 04-18-2017, 08:31 AM
  #35
Engine: 535d
I don't think the specs for that ring is close enough.
The thickness of the original ring (1,4 mm) is almost double the size as the one on that page (0,8 mm).
I measured the diameter of the ball (BMW part# 41627148797) and it is 10 mm.
Old 06-24-2017, 03:06 PM
  #36
quattromeister's Avatar
My Ride: 535xi wagon
Engine: N54
Originally Posted by Alpine003
This was already done on the touring I bought and I don't miss the power functionality at all.
My wife's MDX has the power liftgate and truthfully, we only used it a handful of times throughout our ownership thus far. Otherwise we normally shut it manually most of the time.
could you supply the part numbers you used? I might go this route besides trying to keep the car original.
thanks
Old 06-25-2017, 09:38 AM
  #37
chadley's Avatar
My Ride: 535xiT
Others have mentioned this, but I'll throw in my advice as well- I drilled a small hole in the lift arm "socket" as tight as I could to the "shoulder" of the ball, and stuck a cotter pin of sorts through there. The arm never pops off the ball now, and I didn't have to order any special parts.
Old 08-23-2017, 04:45 PM
  #38
Engine: N54
could you post a picture of a before (if possible) and an after? Thanks
Old 09-30-2017, 11:26 AM
  #39
losblancos's Avatar
My Ride: '06 530xiT
does anyone have any advice on actually getting the cylinder back onto the [new] ball joint? i can't seem to force it on there.
Old 09-30-2017, 11:31 AM
  #40
Engine: 535d
A rubber mallet or a hammer and a piece of wood would work. I used a hammer and a piece of plastic to pop mine in place on the ball bolt. It has as been working like a charm ever since.
Quick Reply: Power tailgate hydraulic cylinder dismounted
