5Series.net - Forums
-   E61 Touring Discussion (https://5series.net/forums/e61-touring-discussion-4/)
-   -   Pink plug on rear window (https://5series.net/forums/e61-touring-discussion-4/pink-plug-rear-window-154528/)
M6 6MT Nov 13, 2025 03:55 PM
Hi All,
I’m new to the forum and need some help, I love my beemers but occasionally they test us with the most annoying problems, I have a M6 manual swap, a 650i and a 535d touring which is causing me problems at the moment!
I was removing my diversity antenna as I’m having remote problems and the pink plug came off in my hand 🙃
Does anyone know what the pink plug that goes from the rear window to the diversity antenna is for?
it’s not the radio aerial as I have reception.
Many thanks
Calvin
kd7iwp Nov 13, 2025 06:29 PM
It has a 3 wire ribbon cable? Should plug into thr inside of the antenna amplifier if I remember correctly. You might not have much AM or keyless entry range right now. That rear spoiler has the antenna in it and the diversity antenna amplifier is mounted on the glass under the spoiler.
donpb Nov 13, 2025 09:14 PM
Originally Posted by M6 6MT (Post 1624229)
Hi All,
Many thanks
Calvin
@M6 6MT It would help if you posted a photo.
M6 6MT Nov 13, 2025 11:00 PM
Update: When I was locking up last night I tried it again and it’s decided to start working again, and from inside the house so I really don’t know what’s going on with this,
Here’s a photo showing the ribbon cable that’s now not connected to anything……
https://cimg2.ibsrv.net/gimg/5series...1352a2e51.jpeg
donpb Nov 14, 2025 12:59 AM
It's a 3-pin flex cable. It appears you have it plugged in. Why do you think it's not connected to anything?
M6 6MT Nov 15, 2025 09:16 AM
Pink plug
Hi Mate,
Because it came off in my hand, I believe it did go to the rear window until I pulled it off by accident…..
gman6262 Nov 15, 2025 10:14 AM
Those are the connections to the radio antennas embedded in the window glass. If you've torn off the flat harness to the window - you can create new antennas by connecting normal copper wire to that connector and running the copper under the spoiler. Like so:
https://cimg6.ibsrv.net/gimg/5series...2cbe84d86f.jpg
donpb Nov 15, 2025 01:30 PM
Originally Posted by M6 6MT (Post 1624236)
Hi Mate,
You can finagle and reconnect it but if you have ALL radio reception, I wouldn't worry about it.
M6 6MT Nov 17, 2025 01:38 PM
Thanks for the reply……. do you just run a single wire from each pin, do any of them join and route back to the diversity unit?
Cheers
Calvin
