Perks/downsides of the 06-07?
My Ride: Miata Starion Forester
I still haven't picked a wagon up yet, and for the longest time I've wanted boost boost boost - but, to give the N52 a fair shot, what are the pro's and con's of the earlier years - beyond the seats/older infotainment?
My Ride: 535xi touring
Pro: things attached to the engine are less likely to break
Cons: no N54 engine...when running well, it's a sweet engine. But turbos wastegate rattle, fuel pump failure, injectors leaking, and carbon buildup are reasons to check out the 06-07 if you want a bit more reliability
My Ride: 530i
Engine: M54
early N52s had problems with a casting flaw in the cylinder head resulting in abnormal amounts of valve 'tick', basically the bores for the HVAs weren't machined properly. The cylinder head was redesigned for the N52, but by then the E60 was out of production. Not every N52 has this problem, but a decent number of them do. google 'N52 valve tick' to see what I'm talking about.
My Ride: e61 / KW V3 / JB4 / M5 Rear Sway / FDL Coded / SAT Retrofit w GKE flash / ER FMIC / BMS DCI
Model Year: 2010
Engine: N54
