Panaromic roof headliner diagram
Hey everyone-
On my recently purchased E61, I am having an issue with the panoramic roof headliner (not the glass). thankfully, the glass seems to operate correctly. my problem is that the two pieces of the headliner have separated. the front piece operates normally with the switch - it can be moved all the way forward or rearward with no issues. however, the problem is that the rear piece is not attached and seems to be retracted into the headliner. I can see it on the lower track, but the front piece does not pick it up on its way forward. i also do not see that metal vent piece anywhere. my guess is that i need this repair kit (link below) and im going to need to remove the headliner and possibly the whole cassette. does anyone know where i can find a diagram of the whole panoramic roof assembly to better understand how all these parts fit together? I've searched on quite a few forums but havent found any detailed assembly/disassembly info. thanks! https://www.ecstuning.com/b-genuine-...m/54107198619/ |
