Need help with comfort function of window
Need help with anti-trapping of left rear window. I have tested many suggestions I find in this and other forums. But nothing helps. Have also changed the electric motor without result. I'm starting to wonder if the fault could be somewhere else. There must be a control module plugged into the system. Somewhere the initialization must be saved. Does anyone know how the window motors is electrically connected and where such a module is located in the car? If it exists?
This is current situation. There are no error messages on the dashboard when I roll the window up and down. The window only moves a few cm at a time.
My car:
e61 Touring
year 2009
My car:
e61 Touring
year 2009
Thank you for your suggestion. But have tried most of the suggestions so far. I think there is an error in the system, therefore nothing works. I need to learn how the window system is structured. I am very grateful for any help I can get.
XxBimmerBoy95xX
Sep 8, 2016 01:10 AM
sd_dracula
Jun 8, 2011 08:46 AM
