Mechanic's Special
Old 12-23-2016, 12:10 PM
officeboy's Avatar
My Ride: 530XiT
Lightbulb Mechanic's Special
Just got an electrically troubled 2006 in silver for a bit of a deal since it has higher miles and a number of electronic issues. My first BMW as I've been a Saab guy the last 15 years.
Got my Carly in the mail yesterday and did a read codes and reset to see what sticks, but most were things I already knew about.
Anyone want to critique my plan of action? (Since you are just sitting there waiting to get out of the office on a Friday before christmas)
Remove rear hinge covers and spoiler, check harness wires and repair/replace as needed, check and rebuild/replace antenna booster as needed. Takes care of 00ABCA, and maybe 009D12 as well as my lack of am/fm radio.
BST already tested and has good low resistance, so check and replace/repair negative battery terminal, and battery. Might fix 002DED, 0093F9, 0055D0, and 0054C8.
Looks like 3 bad PDC sensors. Might try some cheap chinese ones on ebay to see if they work at all. Will not be fixing at $200+ each. Could swap a good one from the front to the back.
RIght headlight got backed into, (That PDC sensor is also bad) headlight is intact but one mounting point is broken, and adaptive no longer works. Take apart and see about fixing, maybe just replace. Hopefully can find used, $1200 new.
Worry about Heating/AC AUC sensor in the summer (009C54), $75, seems like an easy fix.
One error I didn't expect is "Air suspension failure Code: 00A3C7". But it looks like that is pretty common and might just be a split hose. Will need to get in there and check it out.
Oh and I get some water in the back, but I'll work out the issues with that and probably the sunroof drain. Also rear brake lights are overloading the ground contact. Need to solder in a little support there.
Well, Hi, and thanks for letting me think out loud.
Code:
ID1: 36440654-6ba1-4731-9499-35f508e89db2-869
ID2: d5dddc5f-df4b-42c9-a3b4-e9d3cf822c25-dea-468c
INFO: 0105D7CBADA09A826A5D4C3E311E4
Base: E60 E61
Build-Year: 2006
Faults: 16
ECUs: 35
Filter: just found
Model: 5 Touring (E61) Automatic engine recognition (MotorID=91, Parameter=28)
Battery: 11.4V
ADDITIONAL OBD: OFFNormal communication
Normal connection
normal
B 1
Date: 2016-12-22 21:58:46
Carly Adapter
Version: 22
Device: >motorola< >ghost_retail< >XT1053<
Motor Control:
Engine / Motor
Power-management power failure
Code: 002DED
ABS / DSC / Brake:
Active Roll Stabilization / Rollstabilisierung
ECU not present/no response from ECU
Dynamische Stabilitaets Kontrolle / DSC
Low brake fluid level
Code: 005F45
Steering angle sensor
Code: 005EBA
Airbag:
Advanced Crash and Safety Management (ACSM)
Driver Headrest
Code: 0093F9
Satellite front left door / Tuer vorne links
ECU OK, no Fault Code
Satellite front right door / Tuer vorne rechts
Satellite B-pillar left / B-Saeule links
Satellite B-pillar right / B-Saeule rechts
Satellite center / Mitte
Airbag B-pillar left/ B-Saeule links
Airbag B-pillar right/ B-Saeule rechts
Transmission Control:
Transmission / Getriebe GS 19
Transmission / Getriebesteuerung
CAN message
Code: 0055D0
Klassierwiderstand on the motor
Code: 0054C8
Gear switch / Gangschalter
Instrument cluster:
Instrument cluster / Kombiinstrument
Code: 00A3C7
Central info display / Zentrales Display
Head-Up Display
Light/Rain Control:
Light / Licht
Rain/light sensor / Regen-Lichtsensor RLS
sorry, unknown fault
Code: 00DA44
Light / Licht
right headlight
Code: 009CBF
High-beam / Fernlichtassistent
Heating / AC:
Air conditioning / Klimaanlage
Short circuit to positive or open circuit (AUC)
Code: 009C54
Additional heater / Zusatzheizung
Immobilizer System:
CAS
Park distance control:
Park Distance Control / PDC
Inverter HR
Code: 009E34
Inverter VL
Code: 009E37
Inverter VMR
Code: 009E3A
Cruise Control:
Active cruise control / Aktive Geschwindigkeitsregelung
Sunroof / Roof:
Sunroof / Schiebedach
Audio/Navi/Communication:
Multimedia-Changer / Wechsler
Speech recognition / Spracherkennungs-system
Phone / Telefon
Hifi Amplifier / Verstaerker
Tuner Antenna / Antenne
Hybrid Radio USA
Digital Satellite-Tuner USA
Headphones / Kopfhoerer Schnittstelle
Navigation
CD-Changer / Wechsler
Audio-System
Video
DAB
Seats:
Backrest width / Lehnenbreiteverstellung
Seats / Sitze
Seats / Sitze
Systems:
Gateway
Steering column switch / Lenkstockschalter
Fuel pump / Kraftstoffpumpe
Tire pressure control / Reifendruck Kontrolle
Passive Go System
Power Module
Night Vision
Flexible Bus-Interface / Schnittstelle
Car Communication Computer CCC
Message failure
Code: 00E18F
MASK
Error in the antenna power supply
Code: 00ABCA
Center-Konsole
Night Vision Camera
Car Communication
Anti-theft alarm system:
Interior protection / Innenraumschutz
Theft alarm / Diebstahl Warnanlage
Fault in the battery
Code: 009D12
Chassis:
Air suspension / Luftfederung
Electronic damper / Elektronische Daempfer
Central Control / Zentrale Bedieneinheit
Body:
Automatisches Front Steering
Trailer / Anhaenger
Car Body Module
Tailgate / Hecktuer
Other:
ECU 90
ECU 91
ECU 92
