Lumpy acceleration and engine drone
Old 11-09-2009, 11:43 AM
__CA__'s Avatar
Checksum - you might also be interested to look for a thread on the EGR thermostat problem that affects the 525d (and others). Basically there is a small, secondary thermostat which is linked to the EGR (exhaust gas recirculation) system. The thermostat can fail - stick open - which means the engine takes longer to reach operating temperature (91 degrees C), or may not reach operating temperature at all. This means your engine is running rich, which means more soot in the exhaust, which means more frequent DPF cleaning, and higher fuel consumption. As there is no coolant temp gauge on the dash you don't realise the car is running cool.
I checked my EGR thermostat at the weekend and it was stuck open, so I've ordered the part (?20 or so).
Old 11-15-2009, 05:53 AM
checksum's Avatar
My Ride: BMW 525d SE
Thanks for the heads up I haven't noticed the engine taking a long time to get up to temperature though.
As to the temperature gauge there is a gauge or sorts, its the dashed lines on the rev counter which start at 4k when cold and slowly moves around to almost 5k when at operating temperature (A proper gauge would have been nice though).
I will get the EGR thermostat checked in the next service though only 2500 miles away.
Old 02-16-2010, 03:52 AM
checksum's Avatar
Well its in the Garage today for Service and MOT, I mentioned about the secondary thermostat on the EGR valve and they said they would take a look.
Will report back with outcome
Old 02-16-2010, 11:09 AM
checksum's Avatar
Well no conclusion from the garage but the exhaust pressure sensor has thrown a lot of errors in the computer so it could possibly be the problem.
UltimatePeter
DIY: Do It Yourself
05-12-2015 08:00 AM
YannickVT
05-07-2015 11:45 PM
Steve J
04-17-2015 08:10 PM
Stranger12
04-12-2015 02:07 PM
08-12-2003 11:41 AM
Quick Reply: Lumpy acceleration and engine drone
