5Series.net - Forums
-   E61 Touring Discussion (https://5series.net/forums/e61-touring-discussion-4/)
-   -   Lumbar Support (https://5series.net/forums/e61-touring-discussion-4/lumbar-support-154355/)
Tonybradley Mar 7, 2025 04:58 AM
Lumbar Support
HI
My 525i has two seat switches. One almost vertical and the other horizontal. There are no dials or indicators. But I have inadverantly set the lumbar support. How do i reset it ?
kd7iwp Mar 7, 2025 09:36 AM
If you have lumbar adjustment there is a circular pad with 4 round dots on it.
When you press the forward dot it inflates both lumbar cushions. Press the top button inflates top cushion only, bottom button inflates lower cushion only, rear button deflates both cushions. Nothing is automatic; the longer you hold any of the buttons the longer the pump runs or the longer the deflate valve stays open.
