Locked out of my car
HELP HELP !!! My alarm went off in the night. Went out the next morning and key fob would not unlock door. Tried 2nd key, still no joy. Then tried to manually unlock drivers door but will not unlock !!!! Still locked out of my car 3 days later. Have noticed that the red alarm light on the mirror is not flashing. ANY IDEAS PLEASE ( have read about the diversity attenna problem but cant get into the car to investigate it )
Banned
My Ride: A Car
i dont think there's AAA in the UK. Use the key itself to unlock it but seems like u tried it. Did you turn it the right way? If anything, try popping the trunk then hook up the battery to a battery tender or 12V jump starter and unlocking the car.
Thanks for the replies but have tried all the keys to manually unlock door but know joy. Have tried lifting handle while turning key but apparently that only works on the E39. Dont have a trunk to pop as a tourer and dont know how to pop the hood without being inside the car. Car is stuck on my driveway in Park and hand brake on dont know how i would even get it onto a flat bed !! Please keep your ideas coming !!!!!!!!!!!!!!!!!!!
My Ride: 2007 E61 M5, 1989 Z1
What happens when you insert the key and turn it 90 degrees left or right? The driver's door should unlock. Some effort will be required.
Quoted from the owner's manual "In the event of an electrical fault you can lock and unlock the driver's door by turning the key to the limit positions in the door lock."
My Ride: 2008 Black E61 530Xd - M-sport - Comfort - Advantage
Since you have tried everything else, here`s what I would do (and also what I did):
You should contact the dealer, because they will void your warranty if they are not notified about this. If the doors are not opening manually with the key I think there´s nothing more to do.
2009 winter my car engine was warming up at my home yard (with a full tank) and all of my doors locked and I didn´t have the spare key. It was saturday night so no help available
There was absolutely nothing else to do than use this on a small side window...at that time my car was 7months old so you can imagine the feeling The window repair cost just under 300?
My Ride: Bmw 530d 2004
Attachment 113278
Attachment 113278
Sorry, couldn't help laughing...
- Antti -
