Load cover release
My Ride: E60 530d auto, Proffesional satnav, power tailgate, interior lights, auto dipping mirrors.
Load cover release
Hi,
I have searched but dont realy know what these are called so found nothing helpfull??They are the catches that release the load cover when i open the rear window/tailgate which ware not working, i removed the trim and found one had stripped the brass pinion and the other had been wired the wrong way round?? i called my local dealer and was told they where not available on their own, you need to buy the whole trim which is aprox £120!!! Does anyone know where i might get one (passenger side) i have tried everywhere but to no avail
Just info for anyone else who has problems with this, i found the only way round it (other than spending £120) was to buy a second hand trim piece which i got from Germany via Ebay £31 delivered. I just removed the bit i needed as the trim piece was black. Its also worth mentioning that the face lift version is different and wont fit, although this was not a problem as i only need the motor which will swap over, so its all working nicely now.
My Ride: 535D Tourer - Pre LCI
good work Phil.... a bit late but a few people have replaced the motor with a cheap ebay version - the motor itself is nothing out of the ordinary, issue is getting the correct gear on the shaft...
Yep your right i bought three different pinions and non fitted which is why i had to buy the whole trim.
ahhh in that case I'll not bother with mine I fanny'd about with it as the gear was slipping, got it working for a short period of time, then it went again - given up tbf
jashy247
02-23-2021 05:50 PM
