K-CAN AHM error
My Ride: BMW E61
Hi,
Original Westfalia hook.
I tried to connect the AHM 4R E-Series module number 7160 6850497-01 following the diagram like in the picture. I am showing this module number after VIN, so I bought one.
![](https://i.ibb.co/T0BC8ZY/Przechwytywanie-1.jpg)
The bundle is perfectly made as it should be according to the original. Everything is elegantly fastened.
CAN L and CAN H as well as the rear stop were taken from the harness which is located on the right side of the rear seat.
Yellow is CAN L and black is CAN H.
After connecting the module, the following errors occur. K-CAN cable error.
![](https://i.ibb.co/Htx7QxQ/313282841-437296285230978-780955837217878364-n.jpg)
K-CAN cable error
I thought I had mistaken the CAN, but even after the swap, the same is also true.
After unplugging the module, the errors disappear.
Anyone had a similar problem ??
K-CAN cable error
Did you twist your CANBUS wires?
All CANBUS wire must be twisted pair cable, even short lengths (longer than 1 inch / 2 cm). The twisted pair wire is an essential part of how the differential mode filtering works on CANBUS, and without it, the signal can be easily distorted.
My Ride: BMW E61
The CAN Li CAN H wires are soldered and insulated with the wires in the car. According to the hook connection instructions, CAN L and CAN H signals should be taken from the place marked X15013 / X15014.
![](https://i.ibb.co/Qm2dM3q/CUI9JFjX.png)
I took the signal from this place
![](https://i.ibb.co/Dzfc98X/81o6Pww.png)
![](https://i.ibb.co/4K1rBZT/DZWhNxL.png)
Somewhere I read that it may be a damaged driver?
As for you have your circles together like this Sunday. Is it so important? I let go of the 3 cables in the conduit. CAN L and CAN H and brake light. No twist.
My Ride: BMW E61
