Help identifying this abs controller connector to the pump assembly
My Ride: BMW 2006 530xi Wagon E61
https://imgur.com/gallery/ufcfSL9
Hey everyone any help would be greatly appreciated I sent in the ABS control module for repair and they confirmed that it was working, it was my airbags.com.
There still a problem with the car which is causing it to go into limp mode and have all of the ABS, DSC lights, etc. on. I took the actual motor pump out of the car and tested it on the bench and it turns on perfectly fine when 12 V is applied to it.
That leads me to believe there might be something wrong with this little 5 pin connector. Can anyone help me identify this part, if it’s available to be purchased by itself? Or if not, is this a common part that if I were to buy a used abs pump, could be swapped out without coding etc?
Also, context. I crossed jumper cables in the engine bay last year (I know) and it fried the module, and I’m wondering if this connector is also bad.
mattaebersold
11-19-2019 08:52 AM
