Fuel Pump and Door Lock Issues
Hi All,
I've two queries I am hoping someone will be able to help me with:
Thanks.
GoExplore.
- How much should I expect to pay to get (ball park) the High Pressure Fuel pump changed on my 2008 E61 - I supplied a second hand pump
- The rear passenger door will not unlock or lock with th central locking either using the button on the dash or the remote. All other doors work fine. The lock will open using the door handle. Any ideas what could be causing this?
Thanks.
GoExplore.
My Ride: 2008 BMW 535xi Purchased 2/2011Sapphire Black MetallicNatural Brown LeatherPremium, Sport & Cold Weather
Not sure how many miles are on your car, but the HPFP for the e60/61 has an extended warranty of 10 years/120k miles. I would contact your dealership if you haven't already.
If you've already put a new battery in the fob, could be the tailgate wiring harness or the diversity module. Do some searches for those.
Diagnosis for the HPFP? Either it throws a code, which they can scan in 3 seconds when they get your key, or your car starts to lurch when accelerating (which is when most people take it in) or if you're lucky like me, the the pump just dies without much notice!
And since it's an official recall, if you call a dealer and read them your VIN, they can look up if the new HPFP has been installed on your car already or not, and if it hasn't, you go in and get it done.
Not much to it, either way.
DavaiLave
08-02-2022 02:16 AM
