Front Shock Replacement
Question:
I'm going to replace my factory shocks with Bilstein HD units. When replacing the front shocks, do you really have to go through removing everything from the front suspension per the factory book, or can you just slide the strut up and out of the suspension assy after removing the pinch bolt (i.e. drop the suspension below the level of the strut)? I'm trying to determine if this is something that I can do in my garage, or need to take it to someone who works on BMW's for a living? I have a friend who has the tools to compress the springs, so that is a no-brainer - just removing the struts from the front end of this 530xi sportwagon. Thanks windnsea |
On my E60 525I its easy
I simply removed the pinch bolt and expanded it with a cold chiesel Then I loosened the bolts on the bushes for the two contol arms Undo the top shock nuts and it will drop low enough to remove the shock. But in refitting ensure you have the shock under stress before tightning the bush bolts again |
You can certainly do it yourself.. I just flipped over my suspension last week.. I didn't change the struts but it could have easily come out.
I took off the sway bar end link... and make sure you take off the headlight leveler on the passenger side. I just undid the brake pad wear sensors from the box and the strut, it has enough slack to rotate everything out and free. |
HD shocks
Make sure you put the shocks in right. They are labeled left and right.
Originally Posted by rice_rocket88
(Post 1562137)
.. and make sure you take off the headlight leveler on the passenger side. .
Where is the headlight leveling gizmo? |
E4-WM5-Y132A01- EINBAUANLEITUNG/
MOUNTING INSTRUCTION erstellt am: 04.02.1999 E4-WM5-Y132A01_4 Seite 1 von 2 geändert am: 25.03.04 Tabelle Anzugsmomente - list of torques Gewinde M8 M 10 M 12 M 14 M 16 Thread Anzugsmoment Nm 13 25 45 72 110 10 19 34 54 83 Torque Nm Torque ft lb ZUM LÖSEN UND ANZIEHEN DER MUTTERN DARF KEIN SCHLAGSCHRAUBENDREHER VERWENDET WERDEN DAS BEFESTIGUNGSGEWINDE WIRD SONST ZERSTÖRT. SELBSTSICHERNDE MUTTERN DÜRFEN NUR EINMAL VERWENDET WERDEN! FOR THE REMOVAL AND INSTALLATION OF NUTS, IMPACT TOOLS MUST NOT BE USED BECAUSE THIS WOULD DAMAGE THE MOUNT THREADS. SELF- LOCKING NUTS MUST ONLY BE USED ONCE! Federbeine/ Dämpfer die in Gummiaufhängungen gelagert sind, dürfen erst angezogen werden, wenn das Fahrzeug wieder auf dem Boden steht. Andere Befestigungen (z. B. Schellen) müssen vor dem Herablassen des Fahrzeugs angezogen werden. All rubber- mounted strut/ damper attachments must not be fully tightened until AFTER the suspension system is loaded (wheels on the ground). Other mounting fasteners (for example brackets) must be securely tigh-tened BEFORE load is placed on the suspension system. ALLE DARSTELLUNGEN SIND SCHEMATISCH! KEINE DARSTELLUNG DIVERSER HALTER O. Ä. AM FEDERBEIN! ALL DIAGRAMS ARE GENERALIZED AND NOT TO SCALE! BRACKETS, ETC. SPECIFIC TO STRUT ARE NOT SHOWN! BMW E39/ E60/ E63 BMW E39 touring 22 Nm/ 16 ft lb 72 Nm/ 54 ft lb Befestigungsbolzen 100 Nm; muß mit LOCTITE gesichert werden/ mounting bolt 75 ft lb; must be secured by LOCTITE E4-WM5-Y132A01- EINBAUANLEITUNG/ MOUNTING INSTRUCTION erstellt am: 04.02.1999 E4-WM5-Y132A01_4 Seite 2 von 2 geändert am: 25.03.04 1. BILSTEIN- Stossdämpfer mit Original- Feder 2. BILSTEIN- Stossdämpfer mit BILSTEIN- Feder 3. Original- Stossdämpfer mit BILSTEIN- Feder 1. BILSTEIN shock absorber with original spring 2. BILSTEIN shock absorber with BILSTEIN spring 3. Original shock absorber with BILSTEIN spring Ausbau Das Fahrzeug auf eine radfreie Hebebühne stellen, anheben und Räder demontieren. Bei Fahrzeugen mit Xenon- Licht ist vor dem Ausbau der Federbeine, der Sensor für die Leuchtweitenregulierung auszubauen. Die Schräglenker sind beim Ausbau stets mit geeignetem Hilfswerkzeug abzustützen! Die untere Befestigung lösen und entfernen. Die obere Befestigungsmutter am Stützlager entfernen. Nicht die Kolbenstangen- Mutter lösen! Den Stoßdämpfer komplett ausbauen und in einem geeigneten Spannbock spannen. Die Feder mit einem Spanngerät so weit vorspannen, bis das Stützlager frei ist. Mutter, Original- Anbauteile und Original- Feder demontieren. Hierbei ist zu prüfen, welche Original- Anbauteile durch Bilstein- Anbauteile ( Lieferumfang ) ersetzt werden. Einbau BILSTEIN und/ oder Original- Anbauteile, sowie die neue BILSTEIN- Feder in umgekehrter Reihenfolge, analog zum Ausbau, auf BILSTEIN- Stoßdämpfer montieren. Vor dem Entspannen der Feder ist darauf zu achten, daß die Federenden korrekt in den Ausschnitten des oberen und unteren Federtellers anliegen! Die Einbaulage der Federn ist an der Bedruckung ablesbar. Die Federbezeichnung muß in Einbaulage lesbar sein. Den komplettierten BILSTEIN- Stoßdämpfer in umgekehrter Reihenfolge analog zum Ausbau wieder montieren. Removal Place vehicle on a chassis hoist, lift it and remove wheels. Vehicles equipped with xenon headlight the sensor for the headlamp levelling controller must removed bevor. The lower control arm must be supported by suitable means! Remove bottom mount. Remove top fixing nutsfrom support bearing. Do not remove center nut at this time! Remove complete shockabsorber and clamp it in an appropriate strut vise. Using a suitable spring compressor,compress suspension spring until tension on support bearing is released. Release center nut and remove original mounting parts and coil spring. Please refer to diagram to identify which parts will be replaced with BILSTEIN- supplied components. Install Assemble BILSTEIN and/ or original mounting parts, as well as the new BILSTEIN spring on the BILSTEIN shockabsorber in reverse sequence of removal. Before releasing the spring, care is to be taken to ensure that the spring rest in the cutouts of top and bottom spring plate! The correct mounting position of the suspension springs can be determined by the printing on the springs; install them with the print upright. Fit assembled BILSTEIN shockabsorber to the vehicle in reverse sequence of removal. ThyssenKrupp Bilstein Suspension GmbH August-Bilstein-Str. 4, 58256 Ennepetal Postfach 11 51, 58240 Ennepetal Telefon: (0 23 33) 791-0, Telefax: (0 23 33) 7 91- 4900 Hotline: 01805- 600- 860; Internet: ThyssenKrupp Bilstein GmbH |
Originally Posted by norsecarnut
(Post 1562294)
I read this somewhere else. Does anyone know why? I could understand not starting up the car with the sensor getting crazy input but nobody is going to start up the car during a strut replacement.
Where is the headlight leveling gizmo? Sure.. because if you don't take it off you will break it.. simple as that. It's a little plastic arm that's attached to another plastic arm.. that's on your control arm. When you move it to pull the strut out.. it doesn't bend that way. :rolleyes: |
Got the new Bilstein HD's in -- actually quite easy. Had to unbolt the headlight adj arm off the rt control arm, the sway bar links, and the steering ball joints. Took off the caliper and associated fasteners from the strut and the hub, and you can push down enough to get the job done and the strut out.
I decided to replace the lower control arms and then had a full alignment after it was all reassembled. Car rides great and feels fantastic. A bit more firmer than stock, but I'm going to drop the tire pressure to the recommended unburdened pressure to compensate. |
Did you do both the front and the back? Where did you get them?
Thanks, Greg |
currently Billstein says the rear HD will fit but all resellers say it won't .
| All times are GMT -8. The time now is 07:45 PM. |
